S3 cylinder/power valve help?
'11EC300
Trying to put the power valve assembly into a new S3 cylinder...I cannot seem to get it right!
After many, many, many attempts I keep ending up with the index for the triangle piece on the wrong side of where it needs to be.
The assembly will only rotate a small amount.
Remembering taking it out, the whole assembly being able to spin 360 degrees, so I put everything into the old cylinder and everything seems fine on the first try.
Is it possible something is not right with this cylinder or am I totally overlooking something simple?
After taking a few minutes off and returning to it, I have realized that the flapper can not fully recess in the open position. S3 didn't machine enough material out!
If i were to take a Dremel and try to get a little clearance do I risk damaging the cylinder coating?
Really don't think I should have to but at this point seems like the only thing to do! :mad:
Send it back - the stop points are critical.
Correct me if I am wrong, but the stop points would be controlled by the bolt head stopping the movement at fully open and closed?
The material needed to be removed would be a very small amount on the uncoated side of the cylinder.
Returning the cylinder would be costly ($150-$200) with two way international shipping!
Shoot S-3 an e-mail. I did a few months back,very responsive. They returned my e-mail in a few hours.
Did as John suggested and sent S3 an email and got a fairly quick response.
The response I got was that GG made the flapper in 3 different sizes! Suggested I remove material from the cylinder or flapper to make it clear! :rolleyes:
Well then go ahead and fire up your porting tool. If the part isn't right, one would expect the original seller to cover the shipping.
