rubiconrod
Hi guys.
What I'm wanting to know is which components to leave out when adding oil to the fork.
I have a 2007 EC250 with 45mm Marzocchi Shiver forks. Now I realize that the spring should be inserted after the oil has been added to a predetermined level, but do any of you leave out other components until after the oil height/air gap has been set?
I have read countless posts about suggested levels but there is very rarely any information regarding the assembly proceedure. I did read somewhere a long time ago that the level should be set prior to inserting the spring spacer, spring and rebound adjuster rod, but I have my doubts about this.
As an example;
I set my oil height at 130 mm.
Added spring spacer 115 mm, more than I expected.
Added rebound adjuster rod 107 mm
Didn't take measurement with spring in.
Someone at a bike shop recommended treating the spacer as part of the spring, so if the spring is out then so too is the spacer. However a 53 mm long spacer displaces far more oil than would the equivalent length of spring.
So i'm hoping some of you in the know can shed some light on my dilemma.
Cheers.
As an example;
Cheers.
