Ud_luz
I just noticed Hammerhead has the shifters.
http://www.hammerheaddesignsinc.com/order-gasgas-ggsl.html
We had all but given up on them. We sent them the shift shaft and stock shifter over a year ago and hadn't heard from them.
I'll let you guys know what their response is. I can't believe they switched the bolt around. Did they think Gas Gas didn't know what they were doing?I have a problem with the new Gas Gas shifter. The
pinch bolt has the head on the bottom with the threads
on the top. Did nobody look at the factory shifter?
It is IMPOSSIBLE to tighten the pinch bolt enough to
make the shifter tight on the shaft. Only an open end
wrench may be used to tighten the bolt because the
head is almost touching the frame. Of course the cheap
bolt supplied stripped immediately with a Snap On
wrench so I picked up a grade 8.8. Same problem, it
cannot be tightened up enough.
You need to change the shifter so the head is on the
top and the threads on the bottom like the factory
unit. As it sits this unit looks very nice but is
utterly worthless unless one is willing to unbolt the
engine to use a six point socket or end wrench to
tighten the bolt.
Please feel free to call me.
It uses a 6mm bolt. I'm not sure but I suppose the threads could be drilled out and the bottom retapped for a 7mm bolt.Is there enough material to drill out the existing top threads and cut new threads into the bottom material?
I'm thinking if we show some support for Hammerhead taking the risk of building these units we may well convince some other manufacturers to do the same. It's a thought.
--Bill.
