Silencer mounts/rubber grommets
Jakobi
Could someone give me an idea where I can find some? I've googled, checked auto stores, and hardware stores, and I can't find any in the size I need. My next port of call will be the local bearing shop.
Anyone got a few spares or a bulk pack they're willing to send out for a few bucks. I'll post up the dimensions later. Its for a FMF turbine core (where it mounts to the subframe)
Thanks for the offer Jeff. I have just placed an order for some genuine ones along with a heap of gaskets and other o-rings etc. Easy and cheap enough. Got a spare set for myself too.
Where did you end up getting them from Jake? I need new ones as well. The grommets may as well not be there the silencer can rattle and move around so much.
I just shimmed mine out with a washer for now. I placed an order with motocrosscenter.com and put a couple sets in that order, along with enough gaskets to rebuild the entire engine and a couple more top ends. A few other bits and pieces too. It wouldn't be worth the postage for the gromets alone. I don't know how much OEM in aus is? I couldn't find anything that would fit in bunnings or supercheap. If you get stuck Nathan let me know and I'll send the spare set I ordered down once they arrive.
Ordered these through scotties. Had them in stock and cheap too. Pulled the silencer off to install them and that bloody rubber stopper thing on the guard has worn a hole through the silencer casing. Thought the bike was a bit louder last ride. Time to re-pack it anyway, hoping some quik steel will fill the hole and stay there?
Meanwhile I 'fixed' that rubber stopper with the dremel.
