GMP
Active member
SOLD!!!
EDIT: Added aluminum subframe upgrade kit including new seat. Added plastic frame guards. Bike is now up to latest Euro Race model and likely '14 spec. Only one in US so far. Price reduced to $5000!
Excellent condition and meticulously maintained by super senior rider. 54 hours. This is the most well sorted and detailed '12 you will find anywhere. Nothing bent or broken, all good and ready to go for the rest of the season.
On the bike:
Alloy subframe upgrade kit
'13 plastic frame guards
Scorpion rad frames and grills
Hyde combo skid plate/pipe guard modified with custom mount for '12 frame
Scorpion link skid with custom Delrin slider pad
EE rear brake carrier with shark fin
Aux in-line coolers
Alloy impeller
RBD head mod(pump gas)
JD Blue needle
LTR clutch slave guard
LTR PV cover
2K-2 ignition with 10 oz FWW
51t Ironman sprocket
Fresh DID chain
BRP chain guide
Pivot Pegs
Hammerhead shifter
Cannon Racecraft Silencer
Tubliss system on F&R wheels
2013 fuel tank
Whats so special:
Heim joint brake pedal mod (like a KTM)
Custom shroud mounts
Modified and sealed airbox for better waterproofing
Clutch and ignition covers lapped for perfect fit and no leaks
Steering stops shimmed for maximum lock
Shock mounted silencer and side panels
Whats included:
Extra set of brand new '13 shrouds
Extra set of brand new '13 side panels
Extra set of '12 "XC" graphics
OEM FMF Stealth silencer
Misc OEM hardware, hand guards, cable choke, etc.
original 2012 fuel tank
Notes:
Bike is currently sprung 5.4/.46. The Shock has been revalved by Solid Performance, and the fork by myself with some initial guidance from LTR. I can re-spring back to stock 5.2/.42 for a lighter rider if needed.
Photos show Flexxbars and Scotts damper that IS NOT included. I will install OEM Renthal Twinwalls and include the hand guards.
I have some spares for this bike that I will make the buyer a good deal on, like a wheel set and 300 kit. No spares sold until bikes sell.
I have many more detailed pics I can provide a serious buyer. $5000. A pretty damn good deal.
On the bike:
Aux in-line coolers
Alloy impeller
JD Blue needle
LTR PV cover
Fresh DID chain
BRP chain guide
Pivot Pegs
Hammerhead shifter
2013 fuel tank
Whats so special:
Whats included:
Notes:
