Speedo manual
nato
Anyone know where to find the standard gg speedo manual? For some reason my speedo is not registering speeds.
Double check the little magnet is still on the tab front rotor/hub. It should turn past a pickup every revolution of the wheel. Then trace the pickup back up to the head unit and make sure all is good. I've also seen the ktm speedo drop out when it gets really muddy and the pick up gets so loaded with crap it can't read anymore.
Bike is clean and magnet is still there. Traced it back to unit and all looks as it should. Anyone have a pic of the pickup point on the brake? Mine is just what appears to be the end of a bolt or shaft.
Yep, that's what it is. It's very nicely done. Inside there is a reed relay which makes momentary contact as the magnet goes past. How do the wires look as they exit the "bolt". They are a bit vulnerable there. Can you check you are getting a pulse with a multimeter, or another way, is there a "time moving" counter in your speedo. If that's not going either, it points toward the pickup, or associated wiring. If the "time moving" counter is working, that would suggest the pickup and wiring is OK, and that there is problem within the speedo unit.
Visually everthing looks as it should "New" On the screen everything also looks as it should but its just the fact that when i move there is no speedo or odometre movement.
