splines pattern outgoing gearbox axel
mikhogl
Hello!
does anyone know the spline pattern that gg ec 2013 uses the outgoing gearbox axle. how do you write the technical description for this pattern? I need an axel with this pattern when I design a snow bike kit to gg ec 300.
best regards
I believe they are 14 splines with 22mm major diameter and 25mm minor diameter. I've no idea what the serration angle is though. A sprocket manufacturer would be able to give you the full details.
