twowheels
Fresh out of the crate and ready to ride - but first a few impressions on the new bike. In no particular order ...
* the air filter is the same as last year, but once you get your lunchbox out of the way access seems to be improved over last year. There's lots of sharp plastic under the seat though, so beware.
* the new brake pedal rocks!
* the new Ohlins shock has low-speed compression but not high-speed compression adjustment
* the hard-to-turn knob to adjust rebound has been replaced by a tiny hard-to-adjust allen screw to adjust rebound ... we'll be making a tool for this
* you'll likely have to hit the shrouds really hard to get them to pop out of the grommets - cool. They seem pretty flexible, although this may not be evident on the trail
* the new seat is really light, and it looks like the preferred path for air into the airbox is underneath the back half of the seat. I'm not sold on bolting up into the seat from underneath the fender - sure KTM does it, but the bolt will get packed with mud and you tend to push the seat up when you're trying to bolt it together. That and if gravity is still acting in the same direction as years past a loose seat bolt will be a lost seat bolt and maybe a lost seat.
* steering lock seems to have been diminished with the frame change
* the seat top is tapered at the sides, but seat height is noticeably taller. At 5'11" I can't touch the pads of my feet to the ground, whereas I could almost flat-foot entirely on the 2011 250 Race. Big guys will love it!
* the fastener usage is SO MUCH BETTER
* the new plastic (headlight shell, front fender, rear fender and side panels, shrouds) are fantastic, and the hand-holds under the rear fender rock. The side plates are big enough for real numbers.
* clutch pull with the new Magura master cylinder seems slightly firmer, but more direct
* the coil has moved, as has the CDI which is now located just in front of the fuel tank on the front down-tube
* the boss for the head stay is still on the cylinder head, but it doesn't go anywhere
* my prototype rad braces from 2010/11 bolted right up
* the petcock directs fuel to the right of the bike before looping under the intake and to the carb. Jetting will be slightly more difficult because of this and other clearance issues.
Ride report to follow as soon as I can find a trail without crusty snow and ice ...
