I've had 2 shops now try to remove the swingarm bolt, it will not budge. They have tried penetrant, heat, sockets, mallets, these are decent mechanics. We need to get the engine out to split the cases, but stuck at this.
Any ideas?
Persistance is key. Rig something up so you can get a good perch on the axle without mushrooming it. Remove the footpegs and lay the bike over and chock it up on some timber so each hit with the hammer isn't absorbed by frame movement. Then keep working at it with penetrating oil and the biggest hammer you own. Smack it a few times a day, and it should start moving after a few days of punishment. Once it initially starts moving its generally smooth sailing from there.
Once removed, keep it lubricated.
Any ideas?
How about laying the bike on it's side, heating the bolt then set a candle on for a few moments. The candle will melt and hopefully be your lube. You may also
try a air or electric hammer, but run the chance of mushrooming the bolt.if not carefull.
There are two steel bushings in the cases that the swingarm bolt pass through. More than likely the bolt has rusted to these bushings. If possible, take the bike as far apart as possible, down to the frame, swinger, and engine. The steel bolt doesn't touch any aluminum in any location on these bikes, everything is steel-to-steel contact, which allows rust to propagate with reckless abandon.
Apply penetrating oil between the swinger and the engine cases. Heat won't work right here because you have to get the heat past a fair bit of aluminum, and the cases and swinger will just soak up the heat. You need to get the oil in this small spot and get the oil to wick between the parts. Some heat will work, just don't get too carried away as you will start to get diminishing returns (burning things up).
See about getting a rivet gun with an aluminum drive bar (punch) and have at it. The bolt was stuck on my bike (2011) and it took quite a while, with lots of swearing and beating, to get it out.
God luck.
I wouldn't go too nuts with the big hammer approach. Depending on where it's stuck you could stuff the frame or crack something. I've restored a few vintage mx bikes, and where the swing arm bolt is beyond help I've actually slid one of those very thin grinder blades in to cut it loose. You're up for a new bolt obviously, but at least you're not replacing anything else.
Not sure what year his bike is, but I don't ever recall seeing a steel sleeve pressed into the cases? Then again, I"ve never had my cases split. I have my bike down to the frame right now, I'll check my cases for future reference.
Also a round wire brush, kinda like a bore brush for a rifle works good in cleaning out the bore in the cases of all corrosion to help keep it from reoccuring again.
Good luck!
You want to make it move use something like this. Whether or not it's a smart way of going about it I can't say.
