Need some advice on specs, parts, etc . . to freshen up the top end on my '08 DE300.
The bike lost all compression just before a ride yesterday (I could push the kickstarter through its stroke with my thumb!).
Pulled the top end apart and found a stuck ring (both rings seem pretty well worn). It's a good thing it lost compression, because when we pulled the piston,
we found hairline cracks on either side of the piston skirt - who knows how much longer it would have run before it ate the piston?
So, now we're looking at a new piston rings, etc . .
I have two questions: First, can anyone suggest sources for new parts.
I found a standard size piston on the Wiseco site. GoFasters offers an OEM piston (for $271.00!!). Any other sources?
Second question: Can anyone give me advice on how to judge the wear on my cylinder liner? And if the cylinder is worn, what are the best options?
Reline the cylinder? Replace? Oversize piston? . . . .?
Also, just thought of a third question: Can anyone direct me to a source for the Service Manual for this bike. Something with info like correct cylinder diameter, wear limits, etc . . ?
Thanks for any help you can offer.
