Jakobi
Hello kind people of the Gas Gas Rider Forum,
I'm done with jetting my bike until the season turns again, or I bolt something else on that starts the ball rolling. In the mean time I have decided to really dial in the TTX. The forks I feel comfortable with setting up, but the shock I wouldn't mind some help.
Anyone who used the TTX with the CSC adjuster have some baseline settings they are willing to serve up to get me on the right track? I have started with the recommended 24 clicks out which is ok. I have gone in to 18 which definitely firms things up some, and back out further to make the bike wallow.
The problem I have is when I plow big exposed roots it feels quite harsh in the back. The forks will soak it up but the back slams hard. If I pop the front wheel and wheely right over its not as bad and quite plush. Same with square edged short jumps (that the downhill bikers made). Think short steep face. The front absorbs it well but the back end just wants to skip over. Any thoughts or ideas on what circuit I should be looking at? Rebound or compression??
My approach will be the same as Ohlins recommends, where I use the CSC to get the bike to soak up the big jumps and woops without wallowing, and then fine tune the action with the clickers. I'd just like a bit of assistance on where to start to address that particular harshness.
Sag is set at 35mm/110mm with only 12mm preload on the spring.
Onegreyghost?? I might pm you.
Thanks in advance.
Jake
Thanks in advance.
Jake
