Hi All,
I removed the tank on my 09 EC450 for the 1st time and found this sticker on the underside of the fuel tank below the fuel pump. What is this push and pull sticker actually referring to ?
To disconnect the fuel line between the fuel pump and the injector, I used the a "quick disconnect" coupling I found halfway along the hose. Is this the correct way to disconnect this hose for tank removal.
