It'd be interesting to see if the plug clears up your jetting issue.
I always used the BR8-xx series plug.
BR8ES = standard electrode [cheapest]
BR8EG = fine electrode
BR8EIX = iridium electrode; more intense spark [most expensive]
If your jetting was a bit touchy, then the BR8EIX may help provide a better burn. With good jetting, I had no issues running any of these.
So I'm guessing theese are all acceptable replacments for the Denso W24ESR-U plug my bike came with? I ran BR8EIX's in my KTM's and Husky.
1.5% is 65 to 1.. 927 is probably not very effective at that ratio..
162 main is extremely lean..but the 42 pilot is not...
is your clutch side seal bad?
What elevation and temperatures are you running in? What kind of riding do you do?
Wes.
i don't think so the bike is new but what could be the relation to plug?
i was thinking that if jetting had no effect on plug fouling, the oil had to come from somewhere. the only other place for it to come from is the gearbox oil via the clutch side crank seal... does bike smoke alot?
That main jet seems really lean for sea level. I would go back up somewhere around 175-180 and maybe try dropping the needle. Sounds like its loading up in the technical stuff and then will clear out when you can open it up. Tight stuff is ridden mostly on the pilot/needle setting, so I would start there.
i will try that.
