'12 airboot.
nato
So i have just been cleaning my 300's airfilter only to find just like the original filter it has what looks to be wear marks on it from rubbing against the rear wheel side of the airbox. The filter is stuffed so with 2 filters buggered i start looking why? And it seems the bottom of the airboot is peeling away from the airbox by about 10mm so im thinking this is why it is rubbing on the rear of the box? It also looks like inside the boot is delaminating! I think i have a faulty boot :( Anyone else had this? Not real happy when its my first day of 2 weeks off and wont be able to ride for the whole time aghhh.
Since '07, they have used that airboot design that captures the air box wall in an "H" gasket groove, and provides direct sealing of the filter on the inside flange. An airtight seal between the air box and airboot does not matter, just the filter to airboot flange. What sounds like is happening in your case is that the air box has shifted forward for some reason, causing the airboot to separate from the air box in this area. The boot is molded so I doubt its delaminating. Pull it all apart and you will se what I mean. The air box itself is pop riveted together. You can drill and replace these or use M4 screws and nuts.
It is delaminating as it is doing it on the outside also. It is thin layers of rubber like sticky tape thickness peeling off. I see what you mean by the design but where the boot has moved at the bottom it is forcing the filter back against rear wall of the box.
Thats odd.:confused: For sure get a new boot from the dealer. Try to determine if the air box has moved or if its just the boot.
Odd imdeed. Lucky i looked in there when i did, Would have sucked dealing with a peice of that in the carb
When i look at the filter some more it looks more as if something has melted it. It has not been washed prior to removing it this time. Im a bit confused now:confused:
Get some pics up Nato. Send a couple off to your dealer too. I don't doubt they'll have a new one sent out by close of business.
This is the outside but the inside is similar not as bad though.
Well strange. Is the opening in the airbox still within the groove of the boot? It hasn't pulled or pushed through while flipping the subframe up?? That still doesn't explain the rubber doing the crazy. Haven't changed cleaning products or lubes or anything like that??
The boot was like that when i picked it up, I thought nothing of it. Subframe hasn't been touched. Waiting for dealer to call back.
Looks like my battery is leaking!!! Wish i spotted this before i wrecked a brand new filter :o Still going to get the new boot though as this one is dodgy.
So a new battery, new filter, and new air boot. Should be back on the trail in no time. Is warranty going to cover some of the costs?
Maybe a bad mold process on that boot(temperature, release agent, etc.). Hard to believe though considering modern injection molding controls but who knows how they do it.
They should but a small, flat LiOn battery in a sealed box under the rear of the motor between the frame rails, that pivots down and out of the way for oil changes. A friend and I started looking at a variation of this for his WR250F. It would eliminate all this airbox nonsense and make estart weight more of a non-issue.
Anyone got a part number or some more info on the lighter battery so when i go in i know what to ask for? Thanks.
Look for Shorai, I don't have e-start so don't know the GG OEM battery. I have a cross chart here at the shop but someone may know.
