Jakobi
Double that. Its a sticky in the 2T Engine section. Always at the top of the page. The process is simple. Drain coolant, drain trans oil, remove the pipe and the brake pedal pivot. Remove the pri side cover and pv cover using an 8mm socket. Allen key is used on the pin that attaches to the governor setting. Set it up so that the plate pushes up against the stop under its own force. Reinstall everything. Job done.
