VxZeroKnots
I performed a compression test tonight.
The bike consistently delivered 140PSI, but I live at 6500 feet so with the correction factor of .826 for altitude would put me at almost exactly 170 at sea level.
I haven't done any squish measurements or mods to the bike so I'm inclined to say compression isn't bad.
When I pulled the tank off and went to remove the spark plug the act of brushing my hand against the wire going from the CDI to the coil popped it off it's spade. I put it back in place and removed it on purpose and it took quite a bit more force than just brushing against it to remove so I think I have the smoking gun.
I'm going to pop the carb off, clean it, and check the reeds since I'm 90% of the way there.
The Saga Continues
The Saga Continues
