I have been working on this restoration for about 18 months gathering parts. I am in mid assembly and I ran into a problem with installing the IMS Wide Ratio Transmission. I have a thread on another forum and some of the GG members already know about it. I have 4 of the 5 IMS gears installed without any problems at all. (2 on the mainshaft and 3 on the countershaft). The problem is the last C3 gear on the countershaft fits perfectly but the I.D. of the gear (with the bushing) is too big for the shaft. Any suggestions would be greatly appreciated.
This is the countershaft,the bigger gear is the stock Honda gear and the other gear is the IMS gear. Note the stock Honda bushing(collar)inside the IMS gear. Between C3 and C5 it is a bushing that rides inside C3, there are also a single washer on each side of C3. There isn't a spacer. The I.D of replacement gear is 24.98. The bushing(collar) O.D is 21.99 and the Bushing(collar) I.D is 18.99.I have attached photos showing the replacement gear loosely positioned on C5 without any collar so you could see the gap between gear and countershaft. I also included photos of C3 and C5 which show witness marks that they were previously mounted together. C3 and C5 seem to fit together perfectly except for the bushing(collar).
