I am getting ready to do a top end on my 02 EC300, including setting up cylinder height, squish and compression. My question is this: What base gaskets are typicaly required to set the piston at the bottom edge of the exhaust port? The top end gasket set from 'The motocross center' contains 0.5, 0.3 and 0.15 gaskets, but am unsure if I should order any extras just in case. Obviously there are variations in cylinder/port height and piston height, but a rough idea would be good.
Thanks.
Thanks.
