	I wouldn't be caught dead putting that stuff on my beat to death bike but my son LOVES this kind of stuff. I was going to get him a new hammerhead shifter and one of these too.You realize that the no slot design will allow no free play in the pedal right?
All bling, and it does nothing to address the wear of the hole in the alloy pedal.
I filled the hole with HTS-2000, drilled and tapped it M6. Then get some thin walled steel spacers or M6 weldnuts, and run an M6 bolt with one on each side and a nut on the back. This way, the bearing surface in the pedal hole is eliminated (no wear), the spacers slide in the clevis. As a bonus on the older bikes with the pedal height/stop bolt you can cut the bottom out of the clevis slot and the pedal can be removed without touching the bolt/spacer setup. Very handy for on the trail removal.
 There's still ample freeplay in the MC itself for my tastes. On my '05 MC 250 with no stop to adjust pedal height that slot was just one more factor making the pedal ride to high. I had to lift my foot off the peg to get to the brake. Maybe it's different on the newer frames???
 There's still ample freeplay in the MC itself for my tastes. On my '05 MC 250 with no stop to adjust pedal height that slot was just one more factor making the pedal ride to high. I had to lift my foot off the peg to get to the brake. Maybe it's different on the newer frames???Could you not cut the brake lever part way then bend it down to where it is comfortable for your riding position then weld it the cut back together
I don't like to have the pedal (and my toes) too low at full travel of the system.
