can i add a battery
That pack is intended to be used with their 1 amp charger. You would need to add a voltage rectifier to your bike, but the output might not match up to their battery pack. In that case the battery pack could be destroyed. You also have to float the ground if you add a full wave rectifier.
Simplest solution is to buy 3 battery packs and swap them when riding.
