Hi,
My EC250 started playing up last time I went out on it. It?s gone through two plugs within about 30mins. Although the power seems good, the bike just bogged down and cut out.
Since I?ve had the bike over a year, I thought I?d check the piston/barrel (see photos). There is a small amount of blow back under the piston and very sooty on the top. The barrel seems fine with no major marks and there is very little play in the bottom bearing. There was however considerable play in the top bearing (within the piston). Is this normal?
Based on the above/photos, please can anyone advise me if this needs changing? Could the plug be fouling up/damaged due to other reasons?
