That's not correct, your not carrying around 270Lbs your riding on top of it, in open terrain the 4t is holding a constant speed not wanting to hit band /off band its not vibrating through the bars as much,
Everyone has a different riding style, that said I'm not talking of running down fire roads doing 50 mph. or open desert racing like the Dakar. I'm talking S/T stuff where you are man handling the bike not just sitting on top of it and turning the throttle. I ride with mostly 4T guys cuz I rode my Husky 510 with them everywhere. I love that bike. but at the end of the day you would feel pretty beat up. As far as "Powerbands go...maybe if you had a smaller displacement bike like a 125 or 200 that would matter more. But I can be very lazy in shifting my GG (if I chose to) and spend most of the day in 3rd gear. Have you tried a 300...there is no "Powerband" It's all just a very fluid controlled power. My Husky does vibrate...the GG well it just hums
the 4s is more stable over rocks ruts it doesn't deflect as much as a lighter 2 s, that's all adds up to less fatigue than a 2s,
After Les from LTR does your forks you don't even feel trail trash..you just float over everything.
if you are tipping the bike into corners flat out going up steep hills and tight terrain then yes it is easier with 30lbs less weight,
Is there any other type of riding than that?
but we are only talking about an 8% increase in total weight,
8%, 6%, 2%. I don't care the less weight I have to throw around the better.
2s also require generally more rider input with gear changes clutch work etc.
Same as above
A 4s can do every thing a 2s can with a bit more weight most noticeable in the tight stuff but a 2s on the open road really sucks
Been there, done that...and I really do have to disagree.
