That looks so much easier and cleaner. What if you want to run the no toil with a bead of Bel Ray Salt Water Proof grease around the lip, the No toil won't cut through that will it? I hate the mess with the pertroleum based chemicals but I like to grease the lip of the filter because I ride in a lot of deep sand. Any suggestions?
this is the video i was referring to :
https://www.youtube.com/watch?v=fpzK6Wm_BDs
I knw it is academic and the test is not done with air being sucked through the filter to the carb, but makes you think
