Hey guys,
Thanks for talking about Flexx Handlebars! I know a few of you and am sure I've spoke to you if your one of our great customers. Clay sent me a note concerning this thread. I'm happy to answer any questions you have and provide insight where I can. You guys are pretty spot on so far though!
Just a couple of things. As of last summer both the BRP handguard mount and the Cycra handguard for Flexx Handlebars have been updated to bolt directly into our pivot pin with a 10mm bolt. In the past both set ups used an 8mm through bolt that simply had to much leverage on it to handle the abuse accordingly. The 10mm bolt threaded into the pivot pin of the updated offerings have the structural integrity required, eliminating all bolt issues previously experienced.
We do offer 10mm update kits for the Cycra option.
The Fastway FIT handguard is another great option with one of it's main benefits being it eliminates most of the tweaking of the handguard to sit in the desired position. Similar options are available through BONZ and BRP. This set up does take careful set up as the performance of the Flexx Handlebar can be diminished if the guard is binding. I'm working on a video showing the correct way to install this set up on Flexx Handlebars.
Handguards that mount off of the triple clamp usually will work if set up so the guard does not bind.
Concerning damaging a Flexx Handlebar. Due to the modular construction of the Flexx Handlebar it is easy to assume replaceable parts are available. We do not offer replaceable parts for several reasons. If a main component of the Flexx Handlebar has been damaged the whole system has taken a major shock which could result in a stress riser forming in a separate component than the one showing damage. This stress riser cold allow the bar to fail while you are riding, which is something we want to keep from happening to you. By only offering complete bars we put you in a safer position, which is our #1 concern. We do offer replaceable elastomers, bolts and crossbars.
We are about to release some mounts to more easily mount enduro computers and GPS units. I'll try to post a picture of the computer mount tonight as I have to install my ICO for an enduro this weekend.
Please let me know if you have any questions, concerns or feedback. Thank you for allowing me to talk about Flexx Handlebars.
