front brakes
chchnick
hi guys, had a little issue today with the fluid in the front. After a lot of steep downhills i went to grab a handfull of front brake, i had boiled the fluid and the lever went all the way to my grip, nothing there. As a result i locked up the rear and went up a bank i wasn't intending on doing.
Any recommendations on a better fluid or particular brand, bikes just on 20 hours from new so still stock fluids in brake lines
cheers
Maxima dot 4 rbf 600 series. You will melt the disk before boiling the fluid ( not really)
awesome, cheers. also has anyone tried sintered pads and removed the brake light switch to improve brake feel? the stock feels very progressive. my old bike had brembo's and would lock on really easily.
brake light switch has been proven many times to mess with the brakes, replace it with a non-switch type. (i think the one i got was from an RMZ450)
Just source a Honda banjo bolt. Remove the switch and fit the banjo. Makes a world of difference to feel at the lever.
sweet cheers, also jake just another quick question on the suspension. im 72kg and have sag etc set right but notice she seemed quite harsh last ride out. did you have any recomendations for clickers front and rear on stock valving?
