memphis2857
The GasGas engines seem to go against the established logic. For many years I have been studying and practicing on this and am very grateful to this forum. When I bought my EC 250, I spent some years struggling against instability idle and significant changes with changes not so large temperature and humidity. Searching this forum, I came to the conclusion that one of the reasons was the totally wrong Squish off. Talking to my trusted mechanic decided to check the measure and found 2.4mm. After correcting the Squish (1.00mm) I noticed a huge improvement in performance and also the stability of idling, however this same oscillation which you refer still remained. I tested numerous combinations of needles and jets, and came to the conclusion that in GasGas engines, excess fuel in idle circuit causes this problem, accelerated idle for a few seconds to fall to the ideal rotation. Today, I have a perfect idling, without any changes, but for this a correct fit is necessary that its bearish circuit is fully adjusted without excess fuel by adjusting air screw responding to minor adjustments, otherwise it is impossible from idle and their consequent fluctuations. My guess is that your problem is due to excess fuel in this circuit idle in my case the best combination was a richer needle associated with a higher pilot jet, and not vice versa.
Good luck.
It's not caused by excess fuel. It caused by a lean condition which is why a richer pilot and needle corrected your problem. Hanging idle is a lean condition ALWAYS.
Sent from my iPad using Tapatalk
