If you're sending your head to Dave I'd probably send the carb too
Depends how much you want to spend.
The JD blue is closer to a F diameter needle if I remember correctly.
I watched your mates video (Stu) and his bike sounds like its jetted more like I have jetted mine. Very crisp and clean with a strong top end.
Considerations for top end power are:
1) The 36mm carb
2) The base gasket stack/port timing
3) The compression ratio
Have a look and see how many base gaskets are in it. I think for 2011 they dropped to a single 0.5mm gasket which will probably have your port timing set to favour lower to mid. If you want to shift some grunt up thats something to address when you get the head done. If you get dmcca to do the work he will run sims and give you a graph to work off showing different configurations and plans and how the effect the power curve. Here is the one he did for me. (if you want to read up on the subject see here:
http://www.gasgasrider.org/forum/showthread.php?t=11970)
Stock my 300 ran the port timing favoured for the top end and with the 38mm carb it had more than enough of it for me. Any comparisons since then are bleh as my engine is now a 250 running a slightly modified cylinder, s3 head with custom insert.
The gassers do use a 2k3 ignition which has quite a bit of mass. Shouldn't stop the power coming on though. Just make it less aggressive.
Its really your call on how you want your bike to run. If you're happy with it now then maybe just keep being happy with it! I've tried just about everything under the sun now, and every time I try another setup I keep coming back to the same settings which suit me best.
