Jakobi
Do you have a used spark plug to put in there and check?
What oil, at what ratio are you using? Have you set the float height?? (possibly too low, starving for fuel at extended WOT). Have you checked the intake (carb boot, reed block, and manifold?) Consider inspecting the stator side seal too.
Does it feel lean? Sound tinny? Make the hestitating starving gasping bwaaaah *cough* sound when you whack the throttle open? If you ride with steady throttle and then roll the throttle back does the bike surge forward before the revs drop?
