I have been out riding the hell out of the new bike and loving it!
This thing makes riding easy, I am attacking some obstacles I used to pass by and I'm more confident in the nasty stuff.
Issues:
-I need a little more height out of my bars, I'll probably add some small riser blocks since I like my bars (Fatbar CR High, cut to 29").
-Figured out the footpeg spring issue, have them installed correctly now
-The small electrical device (voltage reg?) attached to the top / front of the airbox snapped it's little aluminum bracket. It didn't seem worth fabbing a new bracket, I just zip tied it into place.
-Clutch squeal is annoying when I have to work it, I'll likely try and make the season like this, it got a little better after the first oil change with ATF. A rekluse basket is on my long list.
-My rear Metzler must have a bead flaw. Takes an abnormal amount of pressure to seat the bead, and when I lower my pressure to 8psi and ride.... one small section of the bead will pop back off. Strange, never seen that before.
I absolutely LOVE this engine. It has the low rpm and torque I need, and still has a very pipey top end. I'm still rich and using the stock needle but it runs so good, I'm in no panic to tune further for now lol.
Suspension is starting to loosen up and feel really good, I have gone out a few clicks here and there, really happy with it. I'm running a lot of sag to reach the ground better with my feet, slid the forks up a bit to keep the rake.
Brakes are amazing, predictable and powerful. Although, the front squeals at times, I'll taper the edges of the pads one of these days to see if it helps.
I hated the seat at first, got through the pain and like it now. It's very firm for my usual liking, but makes it easy to move around the bike and leg clamp it whenever I need to.
