Joing the club for 15
Having an awesome spring! Usually by this date, we are just barely getting started but early snow melt has had us out riding for weeks now. Still stuck in the poplar trees though, it'll be a few more weeks till the pine tree trails open up.
Yesterday I nudged a tree with my headlight, broke one of the locating nubs off the fender. No biggie, seems to still stay in place.
The ATF did not help the clutch growl much, but it shifts nicer now.
That is a nice looking bike! Don't forget to loctite the kickstand bolt or it will come loose and scrap up your swingarm. Don't ask me how I know.....lol....:o
sweet bike!sweet terrain!cant tell for sure if you fitted rad braces in those pics?rad mount tabs are very soft...
keep an eye on your airbox drain ducksbill if youre in water,open the hole a little or remove alltogether.airbox lets water in,which wouldnt matter if it could drain...ive washed my bike and found 1-2in water in there everytime i forgot to remove it.i dont cross much deep water so have left in(opened up)but if i did it would stay out- period.
it is odd that the front axle cap is bottomless,it seems almost deliberate?but why?
Thanks for the compliments guys.
Yeah, rad braces are on my list. I'm on a pretty tight budget so far this year which is why you see me doing stuff like re-cycle my cr250 pipe guard, and making my own tugger strap... I was off work for 4 months after knee surgery in Oct. Plus while I was off, the coal mine I work at had massive layoffs and I got moved to a lower paying job. For now, replacing some worn out boots and knee braces will have to take priority.
I don't cross much water either, but I had noticed the duckbill wont drain the airbox on its own. I'll look into modifying it, or removing it.
Just hit days off, and hoping to smash in 4 or 5 full days on the bike!
Had a great ride yesterday, out in the forest for 8 hours.
I dropped my bike on a log early in the evening, and split the small crossover hose off the left rad. No real damage to the rad, other than mounting tabs got tweaked. When the rad got pushed in, the hose ran into a tab on the frame spar that the cable get zip tied to. Cut the hose, and re-fitted it.
Today a racer buddy is coming to town to ride with us! Should be awesome... he tends to make us push our limits lol.
I need a log counter on my bike lol, yesterday I bet we crossed 2000 logs. Lots of gopro footage to edit when I have a "break day"
Today I put in a set of bar risers, and re-mounted my tail light under the fender where I had cut the inner fender off.
Wanted to give an update on my bike. I have a little over 100 hours now in the 4 months since my season started. My bikes get abused, ridden hard, and I crash / bail several times a ride. My trails are on steep mountains, very tight, technical, and I slip the clutch hard. Not an easy life for a bike, and usually a very good test of durability / reliability.
So.... I'll break it down into 3 sections. The good, the bad, and home-brew fixes I have either come up with, or borrowed from posts on sites like this one.
The Good
-I absolutely LOVE this engine. Even on the stock needle, I am always impressed with how smooth and friendly this motor is. Clearly has more super low rpm torque and smooth transition to mid than any of the KTM300's I ride with / try. To top it off, it absolutely screams in the high rpm.
-Stock suspension / handling is spot on for my use. Soft, smooth, tracks great, and likes to go slow. Strange how a bike can have such a horrible turning radius pushing it around in the garage, but be so crisp and responsive on the trail.
-Appearance. Usually by this point my bikes are starting to look pretty scuffed and dirty. Because GG uses a full wrap decal kit everything stays shiny much longer than the average bike with exposed plastic.
-The GG pipe design. I love how high up they tucked the pipe! It's well out of harms way in most situations. Drastic difference from my other bikes in this area.
-The cooling system seems to keep up better than most, I'm almost always the last one to boil over if at all.
-Side cover gasket is a tin gasket which I love because they never stick and can be re-used!
The Bad
-E-start issues started @ about 3 months from new. OEM bendix is not reliable. I have since switched to a different bendix that is working great so far.
-Snapped kick start shaft flush with the side cover. When replacing it, I found the silver spacer between the kick lever and the side cover was installed backwards from new. This could have been the cause.
-Switches. Dirt gets into the headlight switch assembly and messed with almost every function. I cleaned the factory grease out and left it dry inside. So far so good. Good news is, the buttons pop right out so it's reasonably serviceable.
-Airbox. Filter gets dirty very fast, duckbill drain is useless, battery wires can depress and rub the filter if you don't carefully put the seat on. I removed the duckbill completely and now she drains water at least.
-Hose clamps. I haven't had a problem with the larger ones, but the clamps on the smaller rad hoses up top were loose and leaking slightly right out of the box.
Mods
-I modified removed the inner fender for fear of snapping it and the outer fender in crashes / bails. After this, the outer fender becomes almost indestructible! Ive folded it straight up several times with no damage.
-Rad shrouds. The upper plastic pin setup is weak. I cut the pin off and used a bolt and nut setup to secure this point. They were always popping out before.
-Upper rad crossover hoses interfere with the cable / wiring. The spot on either side of the frame where the cables, and wiring is zip tied to the little frame hoops was right up against the small hoses at the top of the rads. Several times when I layed the bike down, the pressure was enough to cut the hose on the end of the rad barb. I cut the zip ties and re-positioned everything so there was clearance.
-I moved the ign map switch up to the bars... I switch it back and forth regularly, and it's very effective to be in "rain cloud" mode for slippery / tough sections.
-I'm now running a 5009 bendix which required some light modding, but is working great so far, and now I can pop in a new one for $20 - $40 depending on supplier.
Overall, I'm extremely happy with my purchase! My next bike will surely be another GG if they are producing at that point. I sure hope the factory gets back to doing what they do soon.
Awesome to hear! Sounds about right in line iwth my experience. I love the tail light idea and will be copying that.
good report.
Watch the battery .Mine leaked onto the airfilter.Lithium Ion battery is way better.
