john r b
I had hoped to have this report written awhile ago.Sidelined by injury.(8-weeks)
Any way I want to list the mods performed,1- removed stock 38mm carb
installed 38mm airstryker jetting: 170main 38pilot jd blue needle 3rd clip position air screw 1&3/4 turns out #7 slide no notch outside air temp's
were in the low 30 degrees. 2- installed checkpoint p/v cover 3- installed
other protection. skid plate/hand guards,etc.etc.
Loading both bikes shows the difference in weight. 250e vs 200.
Im not sure the claimed 22lb. is correct,maybe 10-15lb. After warming the 200
the throttle was quick and responsive. very nice. Suspension- Sag was set for
my weight 172lbs. ready to ride. pfp 2 turns from soft compression 18 out
rebound 14 out . Riding in a tight singletrack 5mi. loop. First impression is this bike has some go. I did notice a small bog while flogging from corner to corner
Wow what a blast!! I think once the squish is corrected and the cast smartcarb
goes on these improvements will make a lean bike even meaner. I will admit I have limited experience on small bore 2-strokes, but this one screams.
If you keep the R's in the corners. Very usable power across the rpm range,didn't notice a difference in the ign. mapping. left it on sunny.
The suspension was excellent. The bike tracked very well and went were I pointed. the handling of these bikes is flawless. imo. When loading the 200 back in the truck i noticed significant tire rub on the silencer. Heavier spring
may be required,I'll check the front w/ zip tys while I'm there. Thanks.
John
John
