Low down / tickover issue HELP
stevehipkiss
Hi all,
Bike: 2007 ec 300
Just changed my silencer to a Gasgas 'Racing' silencer, runs superbly after tickover,kicks powervalve in slightly quicker.
Problem Ive got is that on tickover it feels and sounds like it is hunting, a kind of up and down on the revs, as I said once moving its fine...Anyone help ??
Please dont guess..you either know about these things or like me,you just guess, my guess being it needs a different jet....:confused:
My jetting is currently 178 / 40,
Hi all,
Bike: 2007 ec 300
Check for air leaks around your intake manifold & whats your Needle??
Cheers, needle is standard, not sure which one, only other thing I have done is adjust float bowls, maybe adjusted too much, would that have a bearing ??:confused:
Not sure what you mean by hunting - fast changes or slow? Normally hunting refers to quite rapid changes and most people experience slower rpm changes at idle.
You wont get many replies if you dont want guesses because this has been the source of much debate and no one is 100% sure. Many bikes have the problem and plenty others don't. Guesses have been:
Pipe
Squish
Needle jet wear
Float height/vibration
Sensitivity to temp change
Spooge build up during long idle
I might be wrong but I think he is refering to a lean condition where the idle area is hunting or running on. The tell tale sound of a 2 stroke that is lean at idle. Hmmm, brap bap bap bap bap bap, instead of brap pur pur pur . Ha ha
Air leak somewhere?
I always thought hunting was that on/off power feeling you get on some road bikes due to being lean for emissions, normally while trying to cruise at mid revs, small throttle.
Well he said once he was moving it was fine. Leads me to conclude it is at idle. I have misunderstood before though LOL
No it was at idle. Just that I wondered exactly what he meant by hunting as a lot of Gassers have idle issues that I wouldn't call hunting.
Oh I got ya. Yeah mine kinda does that too. I had good results this weekend tuning that out though. It is not super consistent but overall it worked good.
