Does GoFasters not have them? Or are they big $$$?
He wants to get away from an allen head
Two tricks should keep you from ever stripping another drain plug: (1) Always clean then allen recess so your allen wrench seats fully(this is the most important) and (2) use a new o-ring instead of the copper crush washer(doesn't have to be tightened as much).Thanks ill try to find the site. Thanks for the specs on the bolt also, I only have a standard thread guage. I have got to get away from the allen bolt this is the second one i have rounded out.
GasGas should put the magnet on the fill plug as well. How much more could it cost? Then you would always have a backup.Yeah im in a pinch now the fill plug will have to do but i want that magnet. When i pulled the drain plug magnet was definatly doing its job it was pretty much covered. I dont want to run that filler plug long as it dosent have the mag.
I wish they would have i would be feeling alot better about running the plug swapped.
You know i bet they have thought about it, those guys from Spain are smart, all the weight of that magnet would kill the low center of gravity. Then you simply couldn't ride one in the twisty tight stuff.
