Diggs345
I can check tomorrow if you like as I have the stock ones out in the shed.
Cheers Mark
That would be great
Cheers Mark
Just got the 48mm Zokes and Ohlins 888 back from the tuner... http://motolabdirtbikes.com/
He did two main things to correct the problem.
First was to replace the cartridge spring with a lighter 1.4 spring. It is noticeably thinner than the stocker and compresses about twice was much (by hand as a ballpark).
Second was to do a KYB-like compression stack. More open and more progressive. He said the stock compression stack was something he'd give to a pro rider. Super stiff. He also closed up the rebound stack with a double dose of smaller diameter shim.
He said it would rebound quicker in the first few inches and go progressively slower when up in the stroke. Previously I'd go over softball and larger rocks with little problem, but have issues with smaller trail trash.
The shock was more of the same KYB-esque treatment. Less compression. Slower rebound.
Next weekend I will test it by working our club's Camp Wood race www.amraracing.com -- It is famous for rocks.
Got my springs back , turns out one is 4.4 and a little , the other 3.9 and a bit , averaging out at 41.6 , the spring length is 475mm , confirmed by twowheels.
I need to make a tool to get into the inner chamber .
