ferguscawley
Where can I buy shims in the uk?
I got them from windwave in the UK - they are the marzocchi importer. Speak to Dan there. He is very helpful.
http://www.marzocchi.co.uk/
You need to remove the compression stack from your forks - on the sachs this is simple as you can just turn the fork upside down, remove the entire compression valve assembly by rattling it out with a 19mm socket. Then its simply a case of removing the nut from the top of the assembly, removing the small spring and piston and then the shims are available toyou.
Its been over 2 years since I did a marzocchi fork so cannot remember exactly how I did it. I thionk you have to split the forks for the marzocchi but am not certain.
Fergus
