OK time for an update.
For those of you in the UK and read TBM, errr yes................that was me!
I had a day with DR Shox suspension tuner, at his test track in Suffolk. ner Rendlesham forrest.
I had a good test, but we only made basic clicker and sag adjustments. But it was good to just ride to test different settings and see how it changed things. It's fair to say, I learnt allot, both about suspension set up and my ridding.
I came away with some things to try as Dr Shox suggested.
1, Changing the oil weight to to 5w oil - tried it, it was sh!t. changed it back before I refitted the forks to the bike, couldn't get anywhere near enough rebound.
2, Oil hight reduce to 140mm air gap - This improved things and got me the full travel of the fork, but still sometimes kicked over logs or rocks.
3, Reduce spring preload spacers - NOW THIS IS THE INTERESTING BIT he said it was ok to run no pre load on the springs. OK, I had 7mm in one leg and 12mm in the other
Checked it before, but only found 7mm. The two spacer were different sizes
So I turned them both down so I now have 0-1mm preload. And it feels allot better, no deflection or kicking now
Now my rebound setting is in the middle of the adjustments, but my comp is 4 clicks from full soft, not ideal. I've been told by DrShox that my comp shim stack looks to be quite soft. This is what I have.....
1, 22x1.0
2, 12x1.0
3, 20x1.0
4, 12x1.0
5, 17x1.0
6, 16x1.0
7, 14x1.0
8, 13x1.0
9, 12x1.0
Now my question is, if this is a soft stack and i'm near the limit of adjustment, whats restricting my Comp adjustment? This is my only thought.........
In my Comp valve the piston and shim stack is bolted to the housing, in the manual it shows it mounted on a stud retained by a nut?
If you can see in the pic, the shim stack is closely mounted to the housing. Could this be restricting the movement/deflection on the shims?
It's the last thing I can think of!
