nick790
Don't ignore the mid-valve...a lot of magic can be massaged out of it
I set the float at 1.5 mm but also used a light (10) face shim.
And while your at it, think about the rebound stack... I had to stiffen up mine quite a bit to cancel out the pogo effect.
I need to go even stiffer on the fork's H/S reb
Where are you measuring you 1.5mm float on your mid valve?
The .10mm face shim makes sense, I may try that
