I have the JD database and I ran the BGL clip 5 against the N1EF clip 1. The BGL is 5-10% leaner everywhere except for one small crest near 1/4 throttle.
I liked it in the rock gardens as the bike didn't load up. I'll agree the CCK is the better all around needle, at least for me at sea level. The BGL did scream mid to top although I would not want to chance a piston in deep sand with that needle during all day operation.
Looking at the N1EF, it seems that profile is what the 300 motors want.... The second, or middle taper of the stock needle is an exact match to the "C" aftermarket needle tapers.
The F is equivalent to the L diameter of the aftermarket needles. CCL would be the exact same stock diameter but different in that it does not have the initial "pilot jet" taper and the last "main jet area" taper. I think the initial taper on the N1EF needle is the equivalent of a very shallow A taper that starts early. Then the last taper on the N1EF needle is very rich, like a J taper to make sure you don't run out of fuel on top.
My bike always loaded up with the stock needle but I might revisit it maybe with a 38 pilot and a 170 main jet.
