Neater crossover thread?
motopsycho87
Just wondering if you guys want to help put together a 'neater' crossover thread. Take screenshots and post images of information depicting crossovers.
I've put this thread in 'chassis' as most parts are going to be chassis, but please move mods if you see fit!
Please, no discussion.
Please, use images only (links always die eventually!)
Front Brake Pad Crossover
Stator crossover (I know because I have this fitted to my bike), requires chopping of terminals.
from electrex.
Engine bearings and seals crossover ec300 2006
ITEM BRAND PART No
1 x SMALL END BEARING INA KBK 18x22x22
1 x LHS CRANK BEARING SKF NJ206ECP - C3 62x30x16
http://simplybearings.co.uk/shop/p1...l+Roller+Bearing+30x62x16mm/product_info.html
33.76+
1 x RHS CRANK BEARING SKF 63/28 - C3 28X68X18
http://simplybearings.co.uk/shop/p1...ove+Ball+Bearing+28x68x18mm/product_info.html
1 x LHS CRANK SEAL KOK 20x35x6 - VITON
1 x RHS CRANK SEAL KOK 38x52x7 - VITON
1 x COUNTERSHAFT BEARING SKF 6305 - C3
1 x COUNTERSHAFT SEAL GENERIC 30x40x7
collar - 25x38x17
Throttle cable for 2001 through (???) EC 300 is commonly found from the same year KTMs. It is MotionPro part number 10-3000.
Throttle tube for my 2001 EC 300 is MotionPro part number 01-0079
Plastic fork guards crossover with a lot of bikes with WP43 forks. Easiest to look up a 2003 CR250 and buy those guards.
YZ kick lever weighs less than OEM and offers a better kicking motion.
2003 YZ250 two stroke.
Part # 5NX-15620-20
'01 front brake
2001 Honda CR 250 front master cyl and caliper rebuild kits fit my '01 XC 200.
RB
Anyone know what bikes use the same rear rotor as my '01 EC 300?
Just a heads, because I tried looking on this forum for a definitive answer as to which rebuild kits will work on our bikes. I have a 2005 EC300 and the front brake was weak. I read that everybody thought the caliper and front brake master cylinder were from a Honda, and that would be correct. I used the following Moose Racing Parts# 0617-0018 for the master and #1702-0091 for the caliper, the Moose kits are actually true Nissin Rebuild kits btw.
According to Moose the front master cylinder is on these bike:
Honda CR125 2000 - 2007
Honda CR500R 2000 - 2001
Honda CR80R 2000 - 2002
Honda CR85R 2003 - 2007
Honda CRF150R 2007 - 2009
Honda CRF250R 2000 - 2007
Honda CRF250X 2004 - 2015
Honda CRF450R 2002 - 2006
Honda CRF450X 2005 - 2015
Honda XR250R 2000 - 2004
Honda XR400R 2000 - 2003
Honda XR650R 2000 - 2007
And the Caliper is on these:
Honda CR125 1987 - 2007
Honda CR250R 1987 - 2007
Honda CR500R 1987 - 2001
Honda CRF150F 2006 - 2012
Honda CRF230F 2003 - 2012
Honda CRF250R 2004 - 2016
Honda CRF250X 2010 - 2016
Honda CRF450R 2003 - 2016
Honda CRF450X 2003 - 2016
Honda XR250R 1993 - 2004
Honda XR650L 1993 - 2009
Honda YZ426F 1998 - 2002
Yamaha WR250F 2001 - 2015
Yamaha WR400F 1998 - 2002
Yamaha WR426F 1999 - 2002
Yamaha WR450F 2003 - 2015
Yamaha YZ125 1998 - 2007
Yamaha YZ250 1998 - 2007
Yamaha YZ250F 2001 - 2006
Yamaha YZ400F 1999 - 2002
Yamaha YZ426F 1998 - 2002
Yamaha YZ450F 2003 - 2007
After rebuild, this thing will throw you over the bars, I have standard banjo bolts. I used a mityvac to bleed, and pushed the pistons in at least three times to reverse fluid direction and help get in any air out. I hope this helps somebody out. Also not all Nissin master cylinders are the same. I had a 1999 Kawasaki KDX with a KX USD fork conversion, and the master cylinders were different, even though the bikes years were pretty much the same. And noticing that moose only lists Hondas for the master cylinder, but Hondas and Yamahas for the caliper, i would say Honda had Nissin do something different for their masters.
Finally got around to figuring out what rear master rebuild kit works for my 2000 XC300. This is the Nissin marked with "1/2" in large numbers.
Rear Master Cylinder, 1990 through 2001 Honda CR500.
Tourmax part 359010 (not available domestically in the US)
AllBalls part 18-1007
OK, rebuilt the Rear Caliper and Master Cylinder on a 05 EC 300
These parts # are Moose (Nissin) kits
Rear Caliper is 1702-0097
1990 - 2001 Honda CR125
1990 - 2001 Honda CR250R
1987 - 2001 Honda CR500R
1993 - 2002 Honda CR80R
2003 - 2007 Honda CR85R
The Rear Master Cylinder is 0617-0020
1987 - 2001 Honda CR125
1987 - 2001 Honda CR250R
1992 - 2002 Honda CR80R
1990 - 1995 Honda XR250R
1996 - 2003 Honda XR400R
1991 - 2000 Honda XR600R
1993 - 2009 Honda XR650L
2000 - 2007 Honda XR650R
1989 - 2006 Kawasaki KDX200
1998 - 2005 Kawasaki KDX220
2000 - 2003 Kawasaki KL250
1987 - 2007 Kawasaki KLR650
2008 - 2016 Kawasaki KLX140
2008 - 2016 Kawasaki KLX140L
1997 - 2007 Kawasaki KLX300
1993 - 1996 Kawasaki KLX650
1995 - 2016 Kawasaki KX100
1986 - 1990 Kawasaki KX125
1994 - 1999 Kawasaki KX125
2001 - 2005 Kawasaki KX125
1986 - 1990 Kawasaki KX250
1994 - 1999 Kawasaki KX250
2001 - 2007 Kawasaki KX250
2004 - 2016 Kawasaki KX250F
2006 - 2009 Kawasaki KX450F
2011 - 2016 Kawasaki KX450F
1986 - 1990 Kawasaki KX500
1994 - 2004 Kawasaki KX500
2000 - 2016 Kawasaki KX65
1988 - 2000 Kawasaki KX80
2001 - 2016 Kawasaki KX85
2000 - 2007 Suzuki DR-Z400
2000 - 2007 Suzuki DR-Z400E
2000 - 2015 Suzuki DR-Z400S
1990 - 1995 Suzuki DR250
1990 - 1999 Suzuki DR350
1990 - 1999 Suzuki DR350SE
1996 - 2015 Suzuki DR650SE
2004 - 2006 Suzuki RM-Z250
1996 - 2008 Suzuki RM125
1996 - 2008 Suzuki RM250
1991 - 2001 Suzuki RM80
2002 - 2008 Suzuki RM85
Hi Guys, does anyone know if there is some crossover part for a countershaft, I mean that whole thing where the sprocket is attached (2010 EC300) ? Thanks!
KTM #0760203070 matches to 2014 ec300 kick start shift seal
Twinair filter for 2001 Honda Cr250 fits good as well
Here is my list.
GASGAS cross over 2007 GASGAS EC300
rear wheel bearings ALLBALLS 25-1458
fork gaurds 2006 cr 250
Kick Starer 04 KTM 450 EXC
Oil drain and oil fill plug 2000 Yamaha YZF 426
Side Stand Trail Tech 2004 ktm 250 SX small modification to stand
2004 KTM seat foam
rear wheel bearing and seals
2 x 6004 2RS
1 x 6005 2RS
32 x 47 x 7 seal
25 x 42 x 7 seal
fronts
2 x 6905 2RS
seals 30x42x7mm
Rear brake pedal 2000 YZF 426
collar - 25x38x17
Throttle cable for 2001 through MotionPro part number 10-3000
2000-2010 Husky and 1991-1993 Suzuki DR250"S" & DR350"S" (must be the "s" models because the standard models are different)
Brakes ?00 to Current Nissin
Honda CR Brake Pads ?87-?01
Air Filters
?92-?96 Honda CR250R
?90-?97 KTM 250/300/360
?94-?96 Kawasaki KX
?00-?01 Honda CR250R
Exhaust Flange O-rings Late Model CR250R
Connecting Rod Honda CR250R
Trail tech side stand
Can someone please post a pic of one on a gasgas . I have a 2011 ec250e and all the side stand parts are missing.Thanks
Polaris Bendix Crossover for 2013 XC300
Any such thing? I seem to recall that it works, but I can't find any thing definite. Does anybody out there in gasser land able to shed some light? Thanks
