Newbie...just bought 2014 300R, need advice
95jersey
Just bought a brand new 2014 300r 2 stroke. While I wait for delivery, I have some basic questions I am hoping the Gas Gas community can help me out with.
1) The recommendation is 50:1 oil mix (synthetic), anyone see an issue with this? Sounds about the same as most other 300's on the market.
2) Handle bars...I see they have a cross bar, but are they 7/8th or 1 1/8th? I use Zeta wrap around handguards and want to make sure I order the right ones.
3) Handle bars...are the base mounts adjustable on the top clamp? If so how many positions?
4) Footpegs...I see they are adjustable and I am kind of tall 5'11". Anyone run them in the lower position?
5) How many teeth come on the rear sprocket? Manual has different options
6) Transmission...the manual shows 2 available? Which one would the EC300R come with?
7) Gear Oil is recommended at 10w-30. That is very light for gear oil? I was thinking 75W
8) Does the hydraulic clutch use standard brake fluid (high temp of course)?
9) I thought I read the stock exhaust pipe on the 2014 is an FMF Gnarly?
10) Who makes a shorter aftermarket silencer without the spark arrestor?
11) How is stock jetting?
12) What kind of sag does the bikes like (100..105)?
13) What weight rider is the stock suspension set up for?
14) I notice the 300 has provisions for turn signals (switch on handle bars). If I bought some of those fancy led turn signals in the handguards, would they work?
Sorry for the massive blast, but this is probably just enough to get me started on the first ride.
* I mix at 40 to1 with this, http://www.cyclegear.com/MOTUL-800-Synthetic-2-Stroke-Motor-Oil?mr:trackingCode=5B73BBDE-CDDB-E311-8BFD-90E2BA028069&mr:referralID=NA&mr:device=c&mr:adType=pla&mr:ad=51808845257&mr:keyword=&mr:match=&mr:filter=18283950120&gclid=CJKpuqamvsICFS0Q7Aod5zcA9A
* This is what I run in mine, http://www.walmart.com/ip/14958681?wmlspartner=wlpa&adid=22222222227009580576&wl0=&wl1=g&wl2=c&wl3=40839599072&wl4=&wl5=pla&wl6=52987236566&veh=sem
*http://www.mpgear.com/bkpt4058/magura-magura-blood-magura-blood-16oz-mineral-oil-for-magura-brakes?gclid=CLaLgOWhvsICFXRk7AodbUUAng
* See post 41 to cut down for silencer. http://www.gasgasrider.org/forum/showthread.php?t=18252&page=5
* Here is the link to the jetting thread, my specs are on post 219.
http://www.gasgasrider.org/forum/showthread.php?t=2162&highlight=jetting+ngce&page=22
* See post 10 for photos from my install. http://www.gasgasrider.org/forum/showthread.php?t=16383&highlight=turn+signals
There are threads with more detail on most of these issues, I'll update with the links when I find them. This is probably not an issue on the newer bikes but I would check that your water pump impeller clears your water pump cover.
Here are the ones I know:
1) 50:1 here - no issues.
2) 1 1/8 with cross bar. You might want to get some BRP hand guard mounts or you're going to have a frustrating time getting it all to fit.
5) 13/48 I believe.
6) 6 speed, although I don't know that I've ever made it up that high!
9) FMF Gnarly
10) Richard Wilson at House of Horsepower makes a nice silencer with or without a spark arrestor
11) I had to rejet both my 2013 300 and 2014 200.
Congrats on the new bike - you're going to love it!
And may I NOT suggest Enduro Engineering radiator guards for this particular bike. They are not very good.
Are your handlebars renthal twin walls? If so the bore on the ends is larger than most and can cause some hand guards to not be able to secure very well at the bar ends.
they are stock as far as I know. I thought I read somewhere they were twinwall copies?
Thanks for all the replies and heads up. Also just want to give a shout out to Halls Cycles. One of the best buying experiences I have had. Very easy and flexible, especially from 900 miles away!!
95Jersey are you from NJ ? If so maybe we could go riding somewere I am in Pa , and it is always fun to ride with other GG riders :)
Yes I live about 1-2 miles from pine barrens. We have a group that rides right out of my house. Your welcome to join. PM me your information.
This bike is SOO F'N pretty. People have said that the engineering and build is quirky and not as finished as other brands. Just from 2 nights of working on the bike, I'd like to say the opposite. I can't speak to the older models. On the new models, the visual build quality looks far superior to my 310 Husky and YZ250. The way things are put together is very concise and purpose built. I love the axle pulls. Also the parts fit very nicely together (better than my Husky). The bike is tight and feels light (no e-start).
I've owned a 2010 model, and a 2013 model. Both kick only, race spec. Both been quite modified in both terms of suspension and engine setup. Both clocked up solid hours. Close to 300hrs on the 2010, and stacking them onto the 2013 (75hrs now).
I would say both have required very little other than normal maintenance. The fit and finish has shown some big gains in the last couple years. I need almost every tool to work on the 2010, the 2013 has been refined to require less. In some areas things are esier to work on, others not.
Had no issues with parts availability (other than with exotic suspension components).
Look forward to hearing your ride report.
