Pedialyte
Rick
Does anyone use Pedialyte as an electrolyte solution in their hydration systems?
If so what is a good mixture to start out with?
Water to Pedialyte ratio?
Compared to Gatorade, what seems to work better?
Thanks
Nuun is much better, in my opinion. I have used it with great success. One tablet per 16 ounces of water will help you during and after an event. I don't use it in my hydration pack, if it's a very long ride I pack it separate, or else I just leave it at the truck and enjoy after the ride.
Low calories, it's an electrolyte replacement, not a sports drink. It makes it a bit fizzy, so wait for the bubbles to settle before twisting the lid down tight.
I go simple.
In my 3 liter C-Bak I add a pinch of salt and a squeeze of lime. If, on the rare occasion I feel like getting creative, I will add a few ounces of coconut water.
It was 105F when I finished riding yesterday. I did fine.
This here? http://www.nuun.com/
Which product?
I my thinking is to add to my hydration pack for use during races.
Thanks
I use the active hydration tablets, 1 tab to 16 ounces and you are set. I would just make sure to clean everything very well, as anything left in the bladder tends to gum it up when the water evaporates. I added it to my pack bladder once, I think that over a long distance it would be beneficial. But, I usually have a bottle all prepared for my return to the rig and sip on regular water on the trail.
Elyte Sport, add a couple oz's to a gallon and some Tang for taste, if you like orange. I have been trying the Camelbac stuff Elixr and that seems to help, but I think the ElyteSport was the best:
http://www.crampnomore.com/
Nothing in it to fur up your bag either :)
Nothing a little bleach won't take care of....100-200ppm works every time:D
Thanks
I always have to clorox my cooler...i am so addlebrained I keep leaving sandwiches and apples in it. Very odd what 105 degrees will do over a week on a damp cooler with free protein in it...ok, odd isn't the right word!
One nice thing about the hydrobak type bladders with the drybag type close. You turn them inside out and top rack of the dishwasher, no matter what sports drink you had its gone from the bag.
I used the pedialite a few times.. it helps but always forget to buy it.
You just made me feel pretty stupid. I've been using "Source" brand roll top (dry bag style) bladders for years and never thought of flipping them inside out to clean them! I'll have to try that next time, thanks!
The day before a enduro ill drink a pedialite, 4-6 bananas, potassium pills, and all the water i can take. The morning of a race ill try and down a pedialite but its tough to do. This is the basic deal i stick w after racing enduros. It works good for me.
I would like to add one bit of info on this thread. I suffer from cramps so have done a fair bit of research into hydration and electrolytes and what i have discovered is that it is person specific.
At the roof i was taking high5 4:1 energy drink that had electrolytes in it, i was then adding additional high5 zero electrolyte tabs to it and that worked for me, but i have buddies i ride with that will ride with just water and drink half of what i drink and not get cramps.
So you need to try things for yourself because over-hydration is just as dangerous as dehydration
You nailed this on the head.. I drank too much water once at an event,, working a national HS out in the sun most of the day. Upper 90's humid and wrong for early spring in Pa! It was a RORR event so its either raining snowing or unbearable heat.. I drank so much water I got really sick. went to see the Dr the next day as I was still really bad feeling, I thought heat stroke etc. He said water intoxication.Too much can throw your body chemistry off or something. Dont remember all the details.
Also the leg cramp thing, I've tried almost everything. I get them in both legs at the same time to the point they clamp up and make my knees crack like knuckles at night. very painful. I walk around with sore lower legs as they are cramping most nights and some days. Will do this for a week or two then go away for a few weeks. Been to several specialists.. nothing.. diet is all I really got recommended. magnesium seams to give me the most benefit but hard to find that in any sport drink readily available.
Been following this...swazi_matt makes a great point. I hadn't considered the individuality issue of hydration. I hydrate pretty well, on an average day(3-6 quarts of water daily). I ride with only water in my hydro-pak(70-100 oz, depending on ride). So far, never a problem w/cramping. Does anyone consider their undergarments when riding/racing? I try, as much as I can, to regulate my core temp with a wicking layer against my skin, and a 2nd breathable outer layer to help dissipate the excess moisture. Perspiration soaked garments not only can cause severe chaffing, but in general just adds misery to an uncomfortable day(even if it's rainy). I feel pretty lucky...More than a few guys I ride with, suffer with aches & pains from old injuries, cramping, fatigue, etc. I ingest a ton of water, and so far it's enough.
I just started getting them this summer, maybe it is the 55 thing. What is weird is that it is just my feet and toes, and by toes I mean they start pointing in all kinds of strange and unnatural directions:Vulcan V's, the finger, curved up, curved down...it's like a possession! Next ride in am trying a few Nunn tabs.
Rob
I just wanted to provide an update to this thread.
This past Sunday I raced the Funky Chicken, RD#5 of the AMA West Nation Hare Scramble in Elkton, OR. The event was super dusty and dry, which lead to more cotton mouth than normal.
I have suffered from cramps before, mainly in my lower legs at other races. I would concider myself to be in decent shape, however I could stand to spend more time on the rowing machine.
I was hydrated, no doudt about that, I make sure that by Friday morning eveything was good to go!
The 7.5 hour drive to Elkton, OR was in a a/c controled pickup and I continued to consume water on the drive up. Every pit stop we made I was "clear".
The plan was to fill my race hydro pack with one bottle of pedialite before the race. My race hydro pack is small, light weight and will only handle about 1 liter so the entire bottle was dumped into the bag.
My race breakfast was bowl of oatmeal, dry whole wheat toast, glass of OJ and two bananas, no sugar or milk in the oatmeal. I ate this at 6:30 am for a 10 am race time.
That liter lasted me the entire 3 hour race and when I was nearing the last few miles it went dry. I suffered no side effects what so ever, no cramping what so ever. The taste was a little strange at first, but I could live with it.
I normally use water in my hydro pack and I seem to consume more water quicker than the pedialite?
My riding gear is about 50/50 vented so I did have some air flowing to help keep me cool.
The pedialite seemed to work for me along with the fact that I was well hydrated.
Post race I consumed another liter of pedialite to re-hydrate. I seemd to recover pretty quick and I did notice that my engery level did perk up within an hour or so after the race.
Thanks for all the feed back and other idea's.
Thanks
