make me feel better?
The EC300 engine can rattle just off idle, it is usually a power valve and favors a specific RPM unique to each engine depending on whether the pv arm is adjusted correctly. This noise can lead a person not used to it to compare it to a rod bearing type noise.
EC300 gearboxs are freakin loud, if the clutch is pulled in, everything is warm and fuzzy, if the clutch is released in neutral instantly a whirr/growl will occur, again, this is the nature of the beast, not a bad trans bearing, some motors and worse, some nearly quiet.
These noises aggravated the snot out of me today, off idle putting through the parking lot at the local track was literally embarrasing, well the knock noise, the trans noise you have to be more attentive to. The bike in question here is a 2011 ISDE 300, but the forums here seem to indicate these "unique" characteristics date back many years.
