It's the fresco
Holy mother of god
It's the fresco
Right I've got this thing back in and running, I did a squish test which was giving me 1.3 MM. Which I was pretty surprised about I thought it would have been larger than that
I also did a compression test, after some advice as I'm not sure what it should be and I am concerned about it being too high
from what I understand 1.3 is the squish to aim for I was just surprised I actually got it
Previously on the dyno it made 45bhp at the wheel with the exhaust and lectron
I didn't check the gap, the rings looks ok, everything is new, the cylinder was sent with the piston to be plated to that size
The piston does have slight movement at tdc so I do t think it's really tight or anything I'm hoping it was down to the high compression hopefully it's ok now it's been dropped......
I took this thing for a quick ride, everything sounds good until you put it under load around half throttle there's a rattle like its detonating..... Could this all be down to running lean although the plug looks good?
It's defiantly internal, it's worrying as its starting to scuff the bore. I have the std insert in now so I'm sure it won't be 1.3 MM as I had that with the high compression insert
I think I will just try to set the rings at 0.5 and richen up and see if there is any change
Yes the cases were split and cleaned out
The noise is only when it's underload around half throttle as pv is opening
I've had the bike running with pv cover off and I can watch it fully operate with no weird noises
My main concern is ruining the cylinder again as it seems similar to the last time
I haven't messed with the timing, but I will go to have a look.
What would change to cause all this?
