hadfield4wd
Looking at wiseco piston and athena gaskets. Any reason not to?
1999 ec 250
Thanks.
1999 ec 250
Thanks.
Oh What is the difference between a, b and c? I've used many wiseco's just never worked on a gg didn't know if there was any special snake oil. Like you said the letter thanks.
Wiseco only lists one piston
While I have an EC200 I am following your progress. Pictures and some videos would be great! I'm learning and need to replace my top end soon.
Keep us posted.
S3 makes the GasGas OEM piston, if I recall - they have A, B and C pistons. Most any Japanese and European two stroke uses that same lettering system. It denotes, I think, an increase of .01mm. A heavily used A cylinder may measure out to be a B cylinder, but without precision measuring, why take the risk of accelerating the wear of an already used cylinder? Granted, there is a bit of leeway here, and many people go up a size with each rebuild. I think it may be even more critical when unsure of cylinder size to get your ring gap set correctly.
The original cylinder on my GasGas was unmarked. It also had spots of aluminum showing through, so being impatient I just replaced it. I was sent an A cylinder and ran an A piston.
Here are the Wiseco part numbers for the EC 250. The last letter indicates size. I added the size next to the part number to show the difference.
01.7307.A - 66.33mm
01.7307.B - 66.34mm
01.7307.C - 66.35mm
If you haven't already found a source for the gasket kit, this one is what you need and the price is fair. It doesn't take them long to get it in and ship it to you either. https://www.amazon.com/gp/product/B00IRWLXRM/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
If the engine sounds good and is a low hour unit I don't feel it's worth it to pull it down for piece of mind. Run it. Mine was a low hr 2000' when I got it and still has the oe top end w/no issues. BTW I am a preventive maintenance kind of guy when needed. What is the comp. psi?Well I'm not sure that I'll get video. I'll take pictures. This is not my first rodeo. I've rebuilt dozens of bikes/atvs. This is just my first GG. So I want to learn as much specific stuff I can.
So I was hoping to order the piston today. However I'm out of town till Friday. So you're basically saying to pull the piston to check the letter and get the same? I don't think it's that worn, there is no discernable issues, however it's the original piston on a low hour bike, this is preventative and piece of mind for my.
Also is the cylinder nikasil'd.
I really appreciate the knowledge on this site.
1999 ec 250
Thanks.
01.7307.A - 66.33mm
01.7307.B - 66.34mm
01.7307.C - 66.35mm
