noobi
The porting on the gasgas is already pretty good for broad smooth power, if you had Eric port it to be more like the ktm 200, then imo, you went the wrong way as far as porting for torque is concerned. When jetted correctly the stock gasgas 200 engine already dorks the stock ktm 200 as far as torque is concerned.
The PV only affects the power delivery further up in the rev range, so I would expect it to be the same in the low revs with it disconnected and connected.
If you have it jetted lean on the pilot and small throttle openings, with a sufficiently rich portion as the bike comes on the pipe this would give you the explosive power delivery you talk of. Going bigger on the pilot and/or raising the needle may help with weak bottom end, but as GMP stated, most of us are in un charted waters now that the porting has been changed.
