Jakobi
I would say that's been more than just a little lean
Come on MrBlah
. . . If anything I now think the measurements I did on the 300 were wrong as they were my first attempt and the maths shows that it should have been closer to 24.12cc instead of 23cc. This gives an uncorrected CR of 13.11:1. What a learning curve these last 2 days have been!
so 13.1 is close to the 12.6 or 12.7 I measured in my 300, easily within tolerances of whatever gaskets they throw in at random. Pretty high for a such a big slug that could be run on any old pump gas.
But 16:1 is mental. Why would they make it so small? Looking up a chart that really is methanol numbers.
I just did many runs ccing the red head insert using a piece of glass some grase and some metho filing in the plug hole. Came out to 17.5cc and I believe all the head inserts are the same volume.
Deck height was calculated from the squish measurement 2.05mm, and I used a dome calculator (http://www.monolithic.com/stories/dome-calculator) to work out the volume based on a dome height of 3.8mm. All cubic mm were then converted to ml.
Combustion chamber vol = 17.5cc
Deck height volume = 7.27cc
Dome volume = 8.77cc
Trapped volume = (Combustion chamber vol + Deck height volume) - Dome volume
I was wowed to see the figure come out to 16cc. Maybe my measurements weren't so sketchy after all. In any case that gives us a really high CR. Imagine what it would be like if I dropped 1mm of base gaskets.
Unless this is for your own personal education and interest, which is cool, your putting more effort into this than is neccessary. If you set the head up for max compression on your fuel source, and min squish accross the band, it will be good and you can move on. It will grunt off the bottom fine and rev out as well. No reason to switch heads unless you have a cheap race gas source and can squeak out a little more compression for more low end, but you had a 300 for that. The 250 will be all you need and then some. Set it up and ride it. It won't hit too hard with that big 2K-3.
PS dmcca pops up in another forum from time to time, so I have heard of him.
The obvious answer I think is the red line though. It takes half of the work out of the equation for you Dave.
