Just another update on the sexy beast!
As most are aware my TTX shock had a 'failure' and has been repaired and revalved by Ohlins USA. I will have it back early next week/late this week and will post an update in its respective thread once getting a ride on it.
The engine is still running strong with loads of compression under foot. The jetting specs of 40 N3CW#3 178 have been running fine with very snappy power and good grunt down low. I feel it might still be a bit lean in the middle as it kind of buzzes up sound wise without as much pull just before it comes on song and then hits super hard. I like it but I have gone a half a clip richer on the needle and dropped a size on the main to see if I can get a bit more torque in the middle where theres a little hole. I've switched between a 175/178 main several times now and both respond well. The 175 feels a bit crisper and I can get a bit more overev out of it so will stick with it for a while.
I need to check the hour meter to be certain but I believe I've got around 60hours on the top end now and moving towards 250hrs total on the bottom end. I have a new piston kit and gaskets ready to roll but not sure if I should try and stretch another top end out of her or pull it down for a complete rebuild. Thats new terriroty for me and I'll need some of the advice of others here to get through that job for sure. Any opinions?
The TTX forks are also due for a service and I'll likely do that when the top end comes down. I'll regrease the headstem at the same time.
I've only attached one pic today. Hard to believe I could put any power to the ground with the old tyre! Sure think the new one will make a small difference this weekend!
