Jakobi
Really REALLY interested to here how this turns out as I also would like to go down for 250 for harescrambles. Wife wont green light a new bike for at least a couple more seasons.![]()
I've just about put 100hrs on my 250 top end now Ernie. I couldn't be happier. Prior to the 250 top end I was running a 300 set up for top end power. Largish squish, moderate compression, ports timed for top. This was with 1.3mm of gaskets and the S3 300 black insert.
From my experience I would say the bike has given up very little off idle torque. It'll still tractor down and pull a gear heigh. Maybe not as well as the 300 did, but enough to keep the bike moving in the right direction. The 250 has a bit more hit and feels more aggressive to ride.. or should I say I feel that I can ride the 250 more aggressively and it rewards you for doing so. The 300 was agro when riden that way but it was always too much to hold onto. Added to that the 300 comes into comparable power around 1000rpm sooner so with the power curve sitting lower in the rpm it was tugging at the arms more often than not. I like that the 250 has the soft bottom end that you can ride all day without issue, and any time you need the power just turn the throttle and you'll have as much if not more than the 300 up top. I'd have to go back to a 300 to evaluate again, but for now I'm sticking with the 250
