So I picked the seals out of the mains I pulled out, and there's no grease left in them at all. Do you think it would be wise of me to remove the inward facing seals? I can't get the outer ones unless if I pull the bearings out again.
Thoughts? Will I get enough splash lub from the crank side to keep them happy? Does this increase the risk of shagging my main bearings if my bike goes for a swim and takes on a heap of water?
When i rebuild mine, i take of both seals from main bearings. Clutchside bearing was with seal from factory
And fail badly...even broke a case. It going now 200hrs without any seals in main bearings and no freeplay when crab flywheel or clutchside either
Someone say it have to take both seals of, it makes sense because then bearing can breathe oil,gas air mixture all time.
Sorry my english...not perfect... I am finish
Sent from Razr MAXX
Maybe not perfectly good English but perfectly good advice.![]()
Jake, where your at now means that you cannot remove the bearings and reuse them without seals. Once you press a bearing out with force across the inner/outer races, its junk.
Just go get some new high quality open bearings from a supplier. You will pay less and get a better, proper part. Put it together right and not worry about it.
If mine lasts through this year, I'll pull it down and do the same. If it goes bang I'll just swap my trusty '07 engine in.
I didn't have to press on either of the races with the mains. With enough heat and cold bearings they dropped in by hand. I just reversed the proceedure and used the torch around the bearing. Flipped the case over and gave it a few whacks against a folded up towl and the came back out.
I picked the seals off. The flywheel side one is a little different than whats expected. Jilkoo. When you put them in without seals which way did you face this one? Note - its also a C4 rated bearing.
I cant remember i put just same way than older one's were in cracked case. I am not expert but i guess doesnt matter which way...i just put same way than factory was put them, because havent find that great forum yet..to ask someone
Sent from Razr MAXX
