Hi Folks,
Was delving into the forks last night to swap to some heavier springs and change the stacks. (Springs are incorrect sold as 0.48kg/m but are same in every way to my original 0.42 so waste of time anyway lol)
I got the rebound piston off and found this arrangement.
Is it a very heavy check valve or an attempt at mid valve?
Damper rod
Spring
6x 14.3
1x 23.3
Piston
Rebound stack
Nut.
I looked through the shiver manual and it only shows a single shim with the spring to operate as a check valve on the rebound piston.
Cheers
Damper rod
Spring
6x 14.3
1x 23.3
Piston
Rebound stack
Nut.
Cheers
